normal or not
Old Nov 28, 2007 | 01:42 AM
turboboy's Avatar
turboboy
Default normal or not
i just installed a short ram intake on my 05 srt4 and when i go down the road you can hear patters of air is then just air back feeding out of the intake ,also is it possible to give a stock engine and or turbo, or a bov to much air if so what can i do to fix that from occuring ...also the loud whistle is normal b/c of the intake right
Old Nov 28, 2007 | 04:33 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: normal or not
youll hear a 'whistle like' sound i guess you could call it under open throttle. hard to explain but an intake makes it sound a lil different. as for the 'flutter' your hearing. when you let off the throttle, youll hear the turbo spinning, the sound is amplified now b/c of the moreroundmetalic tubing of the intake versus the plastic stock intake tubing
Old Nov 28, 2007 | 11:54 AM
srt4ACRboy's Avatar
srt4ACRboy
^^yes and this usually only happens when you are at a lower rpm, (for me at least, i might not be able to hear it because of my bov).
