ma check engine light is on
Old Nov 29, 2007 | 05:32 PM
daporkchop03's Avatar
daporkchop03
Default ma check engine light is on
it sai p2074 which is throttle body aumm leak.. wat should i check fot eh problem
Old Nov 29, 2007 | 06:49 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: ma check engine light is on
throttle body what leak?
actually, looking at the sticky: https://dodgeforum.com/m_328264/tm.htmit says the following:
P2074-MANIFOLD PRESSURE/THROTTLE POSITION CORRELATION
- HIGH FLOW/VACUUM LEAK
not sure but i guess you could start by checking vacuum lines for good connects/ cracks and such. could be something is not sealing up correctly
