Please help
Old Dec 7, 2007 | 02:31 AM
STILL GH3TtO's Avatar
STILL GH3TtO
Default Please help
My tone ring broke in my stock engine so i took my car to Vivid racing to have them install a new block and a 50 trim kit. It took them 3 months and the car was still not finished so i pulled it from Vivid and brought it to UMS tuning. Ums had to re install the turbo and the motor mounts because vivid put them on wrong.....After driving the car for a little over a month its broken again. There is a mounting bracket that the ac compressor and tensioner pulley mount to(a motor mount bolts to the bracket as well) and this bracket bolts up to the block with 4 bolts. Vivid neglected to put the bolt that is under the ac compressor in at all(probably cuz it was too hard for them). The bracket broke at the top and the other 2 bolts broke the nipples off of the block. Would not putting that bolt in cause it to break?? What can/should i do? Should i take vivid to small claims....I am lost....... please any suggestions..........
Old Dec 8, 2007 | 09:56 PM
STILL GH3TtO
Default RE: Please help
any help??
Old Dec 8, 2007 | 10:25 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
You might want to use the search feature. We had a guy with a "tone ring" problem on here about a year or year and a half ago....
Dusty
Old Dec 9, 2007 | 11:51 PM
STILL GH3TtO
i dont need help with the tone ring issue.... Would not putting that 1 bolt in cause the bracket to break??
Old Dec 10, 2007 | 01:13 AM
PSI Chick's Avatar
PSI Chick
they forgot one bolt in four? i highly doubt that caused it to break, and the other bolts to fail. could it have? sure. but probably not.
