Check Engine light
Old Dec 7, 2007 | 06:33 PM
dparsons06's Avatar
dparsons06
Default Check Engine light
Ok so i got my check engine light looked at and the code was P0128, what can this be?
Old Dec 7, 2007 | 07:13 PM
Moparmatt440's Avatar
Moparmatt440
Default RE: Check Engine light
its P0128-THERMOSTAT RATIONALITY. There is a whole section that has all the code right above where you post
Old Dec 7, 2007 | 08:36 PM
dparsons06's Avatar
dparsons06
I should have been more clear, what does that mean i have to change, the thermostat? any thing else i need to do?
Old Jan 26, 2008 | 09:08 AM
1faststage0's Avatar
1faststage0
change the thermostat and clear the code. make sure you add more coolant because you'll probably lose some.
Old Mar 28, 2008 | 02:36 PM
Swanny's Avatar
Swanny
I'm not sure if this is fixed (I'm guessing it is). For the next guy with a P0128, also check out this article - http://www.obd-codes.com/p0128
