fuel return line
Old Dec 19, 2007 | 02:56 AM
  #21
daporkchop03's Avatar
daporkchop03
Default RE: fuel return line
instead of a fuel return line how about a Jet Chip Dodge Neon SRT-4 Stage 2 ...Stage 2-Designed for the performance enthusiast, the Stage 2 features more aggressive programming to make the most horsepower and torque available. Fuel and timing curves are extensively modified for peak performance and drivability. Requires use of 91 octane fuel, 180 degree thermostat and free flow exhaust. Also works well with aftermarket intake systems, mass air sensors, TBI spacers, etc.
Detailed Description
The JET Performance Module for Dodge, Chrysler and Jeep vehicles is a JET exclusive. Dynamic Spectrum Tuning provides power gains across the entire power band-not just at full throttle. Point by point air/fuel ratio, ignition advance and various other tuning points provide performance gains of up to 25 horsepower. Improves throttle response, acceleration and low end torque.
i was told this will do just fine...
Old Dec 19, 2007 | 08:19 AM
  #22
prpaster's Avatar
prpaster
I heard Jet Chips are a waste of money
Old Dec 19, 2007 | 11:44 AM
  #23
flamingpinhead's Avatar
flamingpinhead
Section Moderator
wow, did JetChip pay you for that post? sounded just like an ad, lol
Old Dec 19, 2007 | 03:49 PM
  #24
daporkchop03
no not rteally there buddy so ppl kno wat it is.. i just want to kno if till do any good instead of a fuel return line
Old Dec 19, 2007 | 04:26 PM
  #25
Burnnout's Avatar
Burnnout
No it doesn't have anything to do with a return line there buddy ...... it is a waste of money for an srt-4, and most other cars.
Old Dec 20, 2007 | 11:05 AM
  #26
srt4ever's Avatar
srt4ever
JET Chips = waste of money...
worthless!
Old Dec 22, 2007 | 01:23 AM
  #27
daporkchop03
then wat type of chip would do the car best
Old Dec 22, 2007 | 08:14 AM
  #28
Burnnout's Avatar
Burnnout
No chip...... it depends on what you are trying to do. If you just want a little power by adding something like a chip... then get the Stage 1 ecu.
Old Dec 24, 2007 | 03:53 PM
  #29
Moparmatt440's Avatar
Moparmatt440
The Jet chip stage 2 is good for a normal Neon, I had one on my SXT, it was great but with the SRT like burnout said go with a stage 1 or even a stage 2 like I am doing. How big is the fuel line, I might be making my own just need to know if factory uses 3/8 or 5/16? Plus the other side of the regulator goes back to the fuel tank right?
