Different Vin ok??
Old Dec 22, 2007 | 10:52 PM
04blusrt4's Avatar
04blusrt4
Default Different Vin ok??
Looks like whoever traded in their car left a stage 2 comp in the trunk, but it has a different vin code than my car. Can I still use it? What will happen if I hook it up? I see other people sellling their kits, maybe it will work?
Old Dec 22, 2007 | 11:39 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: Different Vin ok??
you can use any S2 ECU (given you have the rest of the kit pieced together too). but youll just have to send it in to get it reflashed for your car. Flight Systems can do this for you. just need to find the parts to complete the kit.
Old Dec 23, 2007 | 10:22 AM
04blusrt4's Avatar
04blusrt4
Im going to guess since it is in the car it might have already been flashed. Now for the rest of the parts, i guess i am not sure what are the best pieces to put with the s2, I guess a agp wastegate, but what about mbc and injectors? Are the stock injectors (really stage 1's) ok?
Old Dec 23, 2007 | 10:23 AM
04blusrt4's Avatar
04blusrt4
Oh yea, and who is flight systems? A user or a company? Do you have a website?? thx!
Old Dec 23, 2007 | 11:44 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
http://www.srtforums.com/forums/f156...5/index33.html
The above link will get you going....
Dusty
Old Dec 23, 2007 | 12:54 PM
Burnnout's Avatar
Burnnout
Flight systems is a company.... the AGP WGA will be fine... but you will also need the S2 injectors and map sensor.
Old Dec 23, 2007 | 12:58 PM
flamingpinhead
Section Moderator
as i said you can piece meal a S2 kit. you might even be able to find a S2 WGA and/or injectors. i guess you could get whatever injectors so long as they are at least 680cc injectors, comparable to the 682cc injectors that came with the kit.
