oil pressure
Old Jan 13, 2008 | 02:52 PM
Aerorat's Avatar
Aerorat
Default oil pressure
Does anyone know the maxuim oil pressure a stock srt 4 can produce at red line
Old Jan 13, 2008 | 09:09 PM
Moparmatt440's Avatar
Moparmatt440
Default RE: oil pressure
I think I am getting around 45-50 psi I think. If you are planing on getting a oil pressure gauge you will be safe with a 100psi one. And mount it on the side of the head next to the battery. I run at 40 just normal driving and 25 at idle
Old Jan 14, 2008 | 01:31 AM
Aerorat's Avatar
Aerorat
is that over the trans side of the head or back where the exhaust is and thanks for the info
Old Jan 14, 2008 | 05:58 PM
Moparmatt440
Its on the trans side. I think that the WOT oil pressure could also be around 60ish, I know when I start up cold it sits around 75psi for a bit then drops.
Old Jan 15, 2008 | 04:42 AM
Aerorat's Avatar
Aerorat
thx very much you have been a big help
