trans question
Old Jan 15, 2008 | 08:16 AM
drewthatsmenb's Avatar
drewthatsmenb
Default trans question
hey guys the other day when i got in my car and started it i noticed a slight knocking noise coming from the driver side wheel weld and everytime i put the clutch in it would go away i was thinking it was my throw out bearing but before i jump to any concluision i wanted to know if anyone else had this problem and what you guys did to fix it or if it could even be fixed.
Old Jan 15, 2008 | 07:09 PM
Moparmatt440's Avatar
Moparmatt440
Default RE: trans question
I not for sure but have to checked your trans mount, it could be bad? But Im just shooting out idea's
Old Jan 15, 2008 | 07:22 PM
MAssSrTdriven's Avatar
MAssSrTdriven
goes away when u push clutch pedal in. sounds like throw out bearing...however mine always made this knockin noise since i bought it, then i put in a S4 clutch and new throwout bearing and the noise got louder...sometimes i notice i can make the knocking get quiter if im sitting at idle and i push the clutch in and release it real slow, from what i hear this throwout bearing noise is VERY common in our cars, nothing to worry about..
Old Jan 15, 2008 | 07:23 PM
MAssSrTdriven
btw the noise i heard before i changed clutches was as well my throw out...
Old Jan 16, 2008 | 01:31 AM
drewthatsmenb
yea i did some chatting with some of the srt guys around my area and i heard the samething ifigured it was doing this b/c i put in a new clutch and a lighter flywheel but i do remember it doing that before the clutch swap so i guess this discussion is done thanks guys
