How many miles on your SRT-4?
Old Jan 17, 2008 | 09:55 PM
  #21
71RoadRunner's Avatar
71RoadRunner
Default RE: How many miles on your SRT-4?
ORIGINAL: PSI Chick
ORIGINAL: 71RoadRunner
ORIGINAL: PSI Chick
03 with 33k. only problems are the things i broke at the track.
my boyfriend has a 04 with 80k on it. he had three of his wheel bearings go out. that's about it.
Does he autocross his '04?
yup
Thought so. I would love to do that myself.
Mine is low mileage due to being just a few miles from work, but I do drive it almost every day.
Old Jan 18, 2008 | 02:37 AM
  #22
lblackneon's Avatar
lblackneon
I wish I don't have to drive so much. I've been driving my 00 Neon a lot to keep from putting too many miles on my SRT-4.
Old Jan 18, 2008 | 01:41 PM
  #23
Moparmatt440's Avatar
Moparmatt440
Reply to 71 RR, on my next oil change which I will be doing soon, I am going to run the Royal Purple Syncromax in my trans, they said you can run it straight or add the LSD additive, so I am going to try it without, not sure yet. Should I just add the additive just to be safe??
Old Jan 19, 2008 | 10:03 AM
  #24
flamingpinhead's Avatar
flamingpinhead
Section Moderator
31k. only issues i can recall is the TPS, a coolant line coming off, and the stupid oil light still likes to come on for no reason at all. (it had a bad oil sensor: turn the car it comes on, turn the car off and back on and its not on)
Old Jan 20, 2008 | 01:48 AM
  #25
Chris@CTA's Avatar
Chris@CTA
3413kms.
No problems since almost everything is aftermarket (mods and more mods) now.
http://www.ctamotorsports.com/projec...rojectsrt4.htm
Old Jan 20, 2008 | 01:49 AM
  #26
PSI Chick's Avatar
PSI Chick
ORIGINAL: PSI Chick
ORIGINAL: PSI Chick
yup
i'm planning on doing a autox this year, not sure how the car will do though as it's not really set up for it lol. might try a road course if i have the funds....
Old Jan 20, 2008 | 01:18 PM
  #27
MAssSrTdriven's Avatar
MAssSrTdriven
in reply to cheesenip. funny u say that about ur turbo fins, i thought i had a issue with my turbo so i took it out when i was replacing my clutch (just to upgrade) and i have all bent fins of course dodge said there is nothing wrong with it. not to mention the shaft is so loose i can move it without ANY pressure using my pinky finger..typical.
Old Jan 20, 2008 | 04:35 PM
  #28
flamingpinhead
Section Moderator
^oh, but i bet that is normal
or so they will tell you
Old Jan 21, 2008 | 12:34 AM
  #29
71RoadRunner
ORIGINAL: Moparmatt440
I would use the additive as a precaution, you can never be too safe,and in the event of a transmission problem Dodge cannot say it's your fault for not using it.
