Rotors
Old Jan 23, 2008 | 06:50 PM
pepaint's Avatar
pepaint
Default Rotors
Cross Drilled vs. Slotted, I am not sure which ones I should get, and what are some of the good ones out there. None of that Ebay crap either.
Old Jan 23, 2008 | 07:56 PM
srtgtr34's Avatar
srtgtr34
Default RE: Rotors
they are about the same performance wise, it depends about the looks.
Old Jan 23, 2008 | 09:01 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: Rotors
slotted are stronger, cross drilled are more prone to cracking. also consider this, when you apply the brakes it creates a gas that will build up. when the brakes get hotter, more gas is produced which leads to brake fade. cross drilled can only 'vent' when they are not under the pads, where the gas is produced. slotted allows the gasses to be swept outward, away from the rotor towards the wheel at all times. the slots sort of act as a trough for the gasses. me personally, i favor slotted performancewise. but some like the visual apppeal of cross drilled.
