ngk spark plugs v-power
Old Jan 25, 2008 | 12:41 PM
daporkchop03's Avatar
daporkchop03
Default ngk spark plugs v-power
i would liek to kno wat i should space them at and if there alot better then the champions for the vehicle srt-4
Old Jan 25, 2008 | 06:09 PM
Moparmatt440's Avatar
Moparmatt440
Default RE: ngk spark plugs v-power
depends on your mods and how much boost you are running, if your stock then I think its .050, I have mine at .040 I think. they arent that bad, I run the NGK iridium's. Or cars like the hotter spark
Old Jan 26, 2008 | 01:22 AM
daporkchop03
ma boost is at 20 i have cold air intake 3 inch o2 housing 2.5 mopar exhuast stage 2 wastegate nd a boost controller.. so wat should i gap them at
Old Jan 26, 2008 | 04:39 AM
Kapitald's Avatar
Kapitald
well thats too much boost for no fuel mods...the car should run better at 17-18 psi...but i mean if its working for ya then sure go with it....you should get a wideband if you dont have one....
running that much boost i would gap them at .35- .40 i think i have mine at .35 its time for me to get new plugs...
