more wheel hop?
Old Feb 8, 2008 | 08:21 PM
Polishguy33's Avatar
Polishguy33
Default more wheel hop?
I just installed my agp top and bottom solid motor mounts. i took it for a run when the roads dried up a couple of days later. I floored it when i was going about 20mph in 2nd. I got the same amount of wheel hop as i did in first gear. This didnt happen before i put them in. they would just spin. did i install them wrong or something else.
Old Feb 8, 2008 | 10:08 PM
mldsrt4's Avatar
mldsrt4
Default RE: more wheel hop?
yah just keep burnin out its"cool" brake stands, holeshots, clutch dumps, and roll backs, way to go champ
Old Feb 9, 2008 | 09:17 AM
Burnnout's Avatar
Burnnout
I didn't read Polishguy saying anything about doing a burnout there toughguy..... nor have I ever heard someone refer to "holeshot" as a burnout.... but anyway, If you are getting more wheel hop than before you are def. doing something wrong.
Old Feb 9, 2008 | 10:21 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
ORIGINAL: mldsrt4
[sm=dontgetit.gif]
[sm=boink3.gif]
Old Feb 9, 2008 | 03:43 PM
Polishguy33
never mind guy. i tested them out again on a smoother road and work really well. thanks for the post anyway.
Old Feb 9, 2008 | 09:53 PM
808srt's Avatar
808srt
if you are still getting wheel hop after you installed the top and bottom one it could be because you need a tran. mm because you should still be getting a little wheel hop well at least i did but witht he tran. mount it will get rid of all of the wheel hop.
Old Feb 11, 2008 | 06:51 PM
Kapitald's Avatar
Kapitald
Hm?? all i have are the inserts and i have horrible wheel hop in first and spin second...
I know how u feel....i wouldnt want to add some aftermarket parts and have MORE wheel hop lol....that would suck...
