Fog Lights
Old Feb 18, 2008 | 10:18 PM
dparsons06's Avatar
dparsons06
Default Fog Lights
I had to put a new bulb in the left side of the car if you looking at it. for future referance is there any easier way to get it out without taking out the washer fluid reservior?
Old Feb 19, 2008 | 09:55 AM
PSI Chick's Avatar
PSI Chick
Default RE: Fog Lights
not really unless you have small hands. i have little hands and i even had to drop it the last time i had to change a bulb. i have a new set of fogs to go in that i've been procrastinating on for exactly that reason lol
Old Mar 6, 2008 | 08:48 AM
mldsrt4's Avatar
mldsrt4
they actually will pop right out with little effort....take the top adjustment screw out after u pull the black plastic bexel then just get a flat head behind the foglight itself apply some pressure and it will pop right out......and then pop right back in......found out the hard way.....took off drivers side the long way which wasnt bad but then its almost impossible to take psngr side off....so i inspected theo ther side to see how it comes out and i detached the foglight from the bezel and was like oh crap and did it the same way on psngr side with out taking out whole bezel.....VERY EASY
Old Mar 6, 2008 | 05:49 PM
dparsons06's Avatar
dparsons06
Ah, well atleast now i know for the next time
