Spark Plug WIRES????
Old Mar 5, 2008 | 12:08 AM
stocksrt4's Avatar
stocksrt4
Default Spark Plug WIRES????
Whats kind of spark plug wires should I get??
Nology Hot Wires Dodge Neon SRT-4 really expensive but might be worth it let me know?? http://www.cimotorsports.net/motor-s...neon-srt4.html
Or Granatelli spark plug wires 95-05 Neon Dohc/Sohc for a lot cheaper how much difference would there be?? http://www.modernperformance.com/pro...6e02dff1da766b
Or any other kind whats the best plugs for my car and wires where i could tell a difference??
Old Mar 5, 2008 | 03:42 AM
Kapitald's Avatar
Kapitald
Default RE: Spark Plug WIRES????
plugs won't give you any extra super power....but they will smooth out your idle.....theres a spark plug wire test i read somewhere around here...anyway long story short the grantelli's were the best in that test....i want some granatelli's but havent had the time to order any...had to fix my o2 sensor first...
Old Mar 5, 2008 | 09:07 AM
MEandmySRT's Avatar
MEandmySRT
of the 2 choices i would pick the Granatelli wires. i've had the Mopar high performance wire and i'm using the 1200 deg custom 10mm wires from sparkplug.com now, but i actually liked the hp mopar wires better. a couple of times i've had a misfire problem with the high-temp sparkplug.com wires - i shut off the engine, wiggle the wires at the coil and plugs and the misfire goes away. if the misfire problem comes up again i'll probably switch back to the hp mopar wires or try the Granatelli wires.
Old Mar 5, 2008 | 02:42 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
I've had MSDs on my SRT-4 for over four years and they still work and look like brand new.....
Dusty
Old Mar 5, 2008 | 02:49 PM
PSI Chick's Avatar
PSI Chick
wires are wires honestly. ours are 4" long so reisitance isn't a major issue and they should be changed regularly anyway so just buy the cheapest ones you can find.
Old Mar 5, 2008 | 03:03 PM
srt4ever's Avatar
srt4ever
Gratelli..for me...nice wires, very good!!!
Old Mar 5, 2008 | 06:51 PM
Moparmatt440's Avatar
Moparmatt440
Have have Magnecore, they have always been good for me
