boost controller
Old Dec 27, 2004 | 12:22 AM
redline3's Avatar
redline3
Default boost controller
what should i set my boost controller at with stock turbo
Old Dec 27, 2004 | 12:44 AM
NeonOrngBlast's Avatar
NeonOrngBlast
Default RE: boost controller
What year car do you have? The most you can run stock is 18 if it is an '05 you might have some trouble after putting mine on at times it doesnt like it.
Old Dec 27, 2004 | 07:58 AM
LilSparkPlug's Avatar
LilSparkPlug
Dont set it too high with the stock turbo. Youll get a CEL code for Partial throttle overboost. Meaning your car is boosting to much at partial throttle. Not neccessarily a good thing. Past 18 - 19psi the stock turbo really doesn't benefit, and doesn't perform any better if anything youll find the opposite. It just cant flow at such a high PSI.
Old Dec 27, 2004 | 11:49 PM
redline3's Avatar
redline3
it is an 05. is stage one just the computer and will it help if so how much does it cost
Old Dec 28, 2004 | 05:49 AM
LilSparkPlug
Yes its just the PCM, costs around 325. There is a noticeable difference yes. Nothing phenomenal, but enough.
