Turbonetics Evolution
Old Mar 20, 2008 | 12:08 AM
BOISEBLUE's Avatar
BOISEBLUE
Default Turbonetics Evolution
Does anyone happen to be running the turbonetics evolution wastegate? if so i was wondering if you could post some pics.im doing some test and tuning and i have reason to belive my boost controller is hooked up wrong.
thanks.
Old Mar 21, 2008 | 06:33 PM
MChat's Avatar
MChat
Default RE: Turbonetics Evolution
ORIGINAL: BOISEBLUE
thanks.
What kind of boost controller do you have?
Basically you should have a line from your turbo to the bottom port on the WG. If you're running a MBC, the MBC should be in-line on this port.
If you are running an EBC, it depends on the EBC, but for most you should T off the line from the turbo. One line goes directly from the T to the bottom port of the WG, the other line goes through the EBC boost solenoid to the top port of the WG.
http://www.turboneticsinc.com/downlo.../Evolution.pdf
Old Mar 21, 2008 | 08:07 PM
BOISEBLUE's Avatar
BOISEBLUE
yeah. thats what i thought. my mbc seems like a no name brand. it says s&p on it, or somethinglike that,but no matter how i adjust it the boost stays the same. so i guess its back to the drawing boards. by the way, great car!!!!
