Will they fit or not?
Old Dec 31, 2004 | 05:02 AM
SRT4@40's Avatar
SRT4@40
Default Will they fit or not?
Need an answer fast! Will the PT factory 16"x6" fit the srt-4? Nobody seems to know for sure! Looking @ purchasing some from a salvage yard. They are Aluminum 16"x6" with 40mm Backspace 5x100 bolt pattern! Will the fit the SRT or not? Come on guy's I need your help on this one !!!!!!!!!!!!!!!!!!!
Old Dec 31, 2004 | 08:23 AM
A10CrewChief's Avatar
A10CrewChief
Default RE: Will they fit or not?
I am not positive but i think they will...you may need spacers though. I KNOW that ALOT of the SRT-4 owners over in germany use those for their winter tires.
Old Dec 31, 2004 | 12:52 PM
PSI Chick's Avatar
PSI Chick
the pt 15" steelies work fine, but they are a 35mm offset. that size probably isn't going to clear the caliper, and you'll have to run spacers. not really worth it if you're looking for a winter rim, just get the 15's that fit.
Old Dec 31, 2004 | 12:59 PM
RIPSIGUY's Avatar
RIPSIGUY
I just purchased four Toyo Proxes 4 tires for my Stratus coupe. They are actually pretty good in the snow, we had a 6-8 inch storm last week. They don't work as well as dedicated snows, but the car was manageable. I bought it new, and it came with Eagle RSA's, and it was a horror show with those. I still think the tire and wheel deal at Tire rack is the best deal. Good luck.
