need help installing manual boost controller
Old Mar 29, 2008 | 06:42 PM
stocksrt4's Avatar
stocksrt4
Default need help installing manual boost controller
Yes i know i am part retard lol but dont want to mess my car up...could someone please tell me which two lines hook up to the manual boost controller it has a vavle on each side and one hole is bigger than the other. Just wondering where they hook up to be able to properly adjust my boost thanks for the help!
Old Apr 5, 2008 | 01:23 AM
b00rad's Avatar
b00rad
Default RE: need help installing manual boost controller
well first things first, the boost controllers have a one way valve system, so plug the end from ur wastegate to one of the ends, ull notice that ull hear a sucking sound from hose, thats a good thing, now when u plug it in, u should hear the sucking coming from the other end of boost controller, if you dont hear sucking, then u have it on backwards, and trust me dont run ur car with the boost controller on backwards u can really mess things up, so yeah its pretty simple, u just need the have the air pass through the boost controller, to the vaccum side, the i would turn it down alot, then slowly while testing it on the streets, to see how much boost u want, is u have stock fuel and turbo, u might be ok with 18psi, i run it on my car but i have upgraded injectors, but stock turbo, so good luck LMK how it go's and be careful.
