How much Boost on a S0 2004??
Old Jan 7, 2005 | 05:04 PM
joah1660's Avatar
joah1660
Default How much Boost on a S0 2004??
I'm interested in Dynoing my SRT. Does the Dyno tell you the A/F ratio? I want to install a cheap-o MBC but don't want to spend the $300+ to install a A/F meter. I want to try and boost to 17-18psi and fall to 14-15psi on a stock 2004. Is this too much psi (will it run lean)? Thanks for reading this. Also, let me know if there is a group of srt-4 owners that gets together in the San Antonio area.
John
Old Jan 7, 2005 | 05:20 PM
Bruins013's Avatar
Bruins013
Default RE: How much Boost on a S0 2004??
ORIGINAL: joah1660
John
that is fine. boost as high as it will let u...cut is 18.5 so get as close to that as u can. u will hit cut before u go lean, but make sure u r below like 16.5 by redline. most dynos do a/f but make sure u ask.
i run mine at like 18ish (closest to 18.5 that i can get)
Old Jan 7, 2005 | 06:26 PM
doof432's Avatar
doof432
I know that dusty lives in san antonio... there is at least one other srt down there. I live in corsicana, about 4 hours from you.
Old Jan 8, 2005 | 06:10 AM
joah1660's Avatar
joah1660
Thanks for the information! If anyone else has any ideas, feel free to throw them out there.
John
Old Jan 10, 2005 | 06:48 AM
71RoadRunner's Avatar
71RoadRunner
From the way it seems, half of all the SRT-4's produced are in Texas.
