Cam sensor
Old Apr 23, 2008 | 07:38 PM
framusdh's Avatar
framusdh
Default Cam sensor
I just had check engine light come on and took it to dealer. Says there's a faulty cam sensor that I had to order for $67.00. They said they reset everything and the new sensor would be in, in a few days. Driving home I'm thinkin they reset everything and it's drivin alright but what's to stop it from happenning again. Duh, Just got raped by a dodge dealership. Had to look in my pants when I got home to see what kind of sex organ I had.
Old Apr 23, 2008 | 07:56 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: Cam sensor
Welcome to Dodge Forum!! Let me move you to our SRT-4 Section...
Dusty
Old Apr 26, 2008 | 08:27 PM
Pressurecooker's Avatar
Pressurecooker
What kind of fault code?
Turn the key to on, (but NOT to crank the engine), and off and on. (3X) On the third "on", you should be able to read a fault code on the odometer. It will belike a P, O, and some numbersie; PO1422 or something like that. You have to do this key on and off 3 times within like 5 seconds for it to work. Once you have the fault code, you can look it up here. This will help all of us help you.
Old May 2, 2008 | 05:29 AM
framusdh's Avatar
framusdh
Thanks cooker, I'm no mechanic so this helped, got raped by dealership. I guess I deserve it, taken it to them. dave h.
