Replacing Door Question
Old Jun 2, 2008 | 12:58 AM
monkeyboyx's Avatar
monkeyboyx
Default Replacing Door Question
Yes I know this is probably in the Q&A so please don't kill me over this but I need this answered quick.
Are the doors in the SRT-4 and regular neon the same. The regular neon has the words dodge and a strip in the middle of the door but the SRT has none just a strip on the bottom.
[/align][/align]1.) What im asking is can I use the door from the regular neon and remove the lettering and the strip?[/align][/align]2.) Is their a wiring difference between the door in regular and srt-4. Power mirrors, speakers, windows and lock or different shape connectors or sockets and would I have to spaw everything?[/align][/align]Has anybody done this one on the forum to save some $$$.[/align][/align]Thanks in advance.[/align]
Old Jun 2, 2008 | 09:09 AM
ACCLR8N's Avatar
ACCLR8N
Default RE: Replacing Door Question
The doors are the same, but the wiring would be differennt as far as the speakers go.
Old Jun 3, 2008 | 04:29 PM
LilSparkPlug's Avatar
LilSparkPlug
The plugs are identical between the two cars. The only thing you would have to make sure of is that all of the wires are the same between the one that you had before and the one you are replacing.Some neons had heated mirrors, sothere will be an extra wire for those but its no bigdeal.The doors are identical as well, with the exception of a couple of things that you have already noted.
Old Jun 4, 2008 | 06:51 PM
monkeyboyx's Avatar
monkeyboyx
Yup the 01 door fits fine just need to move over the hardware and wireing. For the other side I was able to get the passanger rear door from a 04 neon in silver...got lucky again. Now does anybody know if the silver in 01 was a different shade then 04? Worse case one of the doors would have to&nbsp\\;be painted.
Getting everything in the same color is a pain and is&nbsp\\;taking time. Or my car would have looked like superman icecream by now. \\
Would anybody have a rear bumper and rocker panel molding in SILVER for sale. PM me if you do.
&nbsp\\;
Thanks for help. Will post some pix when im done.
&nbsp\\;
Old Jun 5, 2008 | 12:18 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
it was all PS2 Silver. however, given the cars are a different age, had different exposure to any number of variables (causing fading)... the shades may not match up perfectly.
Old Jun 5, 2008 | 05:50 PM
monkeyboyx's Avatar
monkeyboyx
The weather effect might change the color a bit for sure. I have both doors in the house and under the light they look the same. Well will see when I get on the car.
Old Jun 5, 2008 | 09:06 PM
LilSparkPlug
The only code for silver on the neons was the PS2 as Flamingpinhead said. You may be better off buying R/T skirts, you'd probably get them cheaper than the one factory SRT piece. Its gonna be tough trying to find a rear and side skirt in that color, you may have to go through a dealer. Or if you're lucky find one in a junkyard.
