Need some help STAGE 3 turbo
Old Jun 22, 2008 | 09:13 PM
ACCLR8N's Avatar
ACCLR8N
Default RE: Need some help STAGE 3 turbo
Well, if I can help in any way, let me know.
Old Jul 1, 2008 | 12:21 PM
srt421's Avatar
srt421
whats the difference between the stg 2-3 upgrade, and the stg 3?
also how hard is install?
Old Jul 1, 2008 | 03:49 PM
Plan B's Avatar
Plan B
The S2>S3 upgrade is sans injectors, MAP sensor, TIP sensor, and toys if you've got them since the S2 & S3 kits share these same parts....
The full S3 kit comes with what is listed above + turbofold, O2 housing, Fuel rail, PCM, and fuel pump.
Install takes a bit. Need to drop the fuel tank to install the pump. And replacing the turbofold can take some time as well. Everything else (aside from wiring in a toybox) is pretty simple and straight forward...
Old Jul 1, 2008 | 05:21 PM
srt421's Avatar
srt421
is 2700 include toys? and how long would it take to get it?
