safc Map or TPS
Old Jun 9, 2008 | 11:27 PM
1fast04neon's Avatar
1fast04neon
Default safc Map or TPS
hooking up safc should i go with the map signal of the tps signal i had the map for a while now and was having trouble because i was hitting 100% at quater throttle i switced to tps signal with a jumper wire and wanted some imput before i accually wire it- thanks
