Kicker Sound System
Old Jun 17, 2008 | 04:09 PM
monkeyboyx's Avatar
monkeyboyx
Default Kicker Sound System
How much work is it to install the upgradedfactory kicker sound system in a SRt-4.
Well lets say if I had the speakers, sub and wiring harnes for the inside of the car.
How many wire are different from the stock sound system to the kicker ordo I have to run some cables all the way to the radio.
Has anybody done this.
Thanks
Old Jun 17, 2008 | 10:08 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: Kicker Sound System
not sure if its prewire for it. although i will say that i wouldnt pay near retail for one, as you could have much better custom system for that amount.
Old Jun 17, 2008 | 10:10 PM
flamingpinhead
Section Moderator
perhaps check where the sub would mount in the trunk? might be the best place to check first.
Old Jun 17, 2008 | 10:11 PM
flamingpinhead
Section Moderator
if its a good deal to pick it up, why not upgrade
hell to post, damn this is pissin me off!
Old Jun 18, 2008 | 12:04 AM
monkeyboyx's Avatar
monkeyboyx
Thanks for the info. Yes I was able to pick up everything cheap so once I figure it all out will post some pictures and write up if it works.
This question is off topic but I take it your suppose to drain the OCC every so often is that correct? The car that I just got has one. Need to post a picture of the engine so people can tell me what that hell the precious owner did their.Sorry about the off topic again.
Old Jun 18, 2008 | 06:11 AM
AWH's Avatar
AWH
Most of the wiring should be the same but you will have to run audio and power wires from the headunit to the sub it is not pre-wired as far as I know, but mine is a 03 so the kicker system wasn't available that year anyway - I went aftermarket in mine.
Old Jun 18, 2008 | 10:35 AM
flamingpinhead
Section Moderator
ur good. yeah, i will usually dump mine every other oil change or so, i just look at how much is in it. when its bout half full i dump it out. mine is pretty large though. just keep an eye on it and dump it out when it needs it.
