hey i jus got my srt4 bout2 months ago. it jus started overboosting, my check engine light came on. but idk wat caused the problem. so does anyone have any ideas?
yeah check the Wastegate...vaccum lines really help you loose boost. but if your overboosting sounds like the Wastegate like someone turned it up...has it had fuel cut off?? cause if it is hitting fuel cut then just upgrade to Stage 1 computer and that should solve the problem!!!
