Motor mounts bolt keep snaping!!!?????
Old Jan 26, 2005 | 04:12 PM
RIPSIGUY's Avatar
RIPSIGUY
Default RE: Motor mounts bolt keep snaping!!!?????
Dude, How the hell are you launching that car? Snapping bolts like that you must be putting down a 1.7 sec 60' time! Something is wrong if you keep snapping them. Find out where PSI Chick got her 12.9 bolts. If you break those you have problems.
Old Jan 26, 2005 | 04:43 PM
LilSparkPlug's Avatar
LilSparkPlug
Deyeme Racing sells the 12.9s
Old Jan 26, 2005 | 05:56 PM
Black04's Avatar
Black04
PSI, I saw the mount your talking about not broke, I just ordered the Boomba mount and 12.9 grade bolts give them a try. I have know clue what my times are. The last time a ran it was stock and pulled a 13.8 1/4 I am hopeing to hit the track Friday and find out.
I dont know whats up with the bolts???? crazy to me
Old Jan 26, 2005 | 06:02 PM
LilSparkPlug
I've heard great things about the Boombas but PSI Chick and I discussed this in another thread that the opening in the mount just doesnt look right. I'll probably get the mount that exhaust depot has. The JLM solid upper mount, which for street use you can use your stock lower mount with and have over 90% elminated wheel hop.
The dogbones create bad vibrations and horrid power steering noises. Yuck.
Hopefully the 12.9s work for you, cause I don't know wth your doing. Your only running a 13.8 and your blowing **** like no other....doesn't seem right.
Old Jan 27, 2005 | 03:32 PM
Black04's Avatar
Black04
Sexy,
had not talk to you in a while I think we need take over some threads again[8D]
Anyway stock was 13.8
mods now
Custom Made 3' DownPipe, Custom Made 3' Exhaust, K&N Cold Air Intake,Apexi Twin Chamber BOV, Mopar BOV, Custom Made Intercooler pipeing, Boost Controler 20PSI
the first time it broke it was on the stock mount and bolt (little wheel hop) never been touch or taken out!, Second time Dogbone **** with dealer mount(spun tires thru 1st gear but did not feel like wheel hop since the windshild wipers never came on) (8 grade guess I thought they were a 10) Snap the bolt completely in half[:@]
