over boost code
Old Jul 16, 2008 | 11:07 AM
jnmopar71's Avatar
jnmopar71
Default over boost code
will this code do any thing bad to my car?
Old Jul 16, 2008 | 01:25 PM
PSI Chick's Avatar
PSI Chick
Default RE: over boost code
put you in limp mode and depending on how lean you're running you could pop the motor
Old Jul 16, 2008 | 05:13 PM
jnmopar71's Avatar
jnmopar71
so what should i do? "pop" you mean blow it up? should i swap the agp wtg with the stock one?
Old Jul 17, 2008 | 03:51 PM
STILL GH3TtO's Avatar
STILL GH3TtO
you can leave your agp one on but lower your boost. What are you boosting now? you should not be over 15-16 psi. And yes she means blow your motor
Old Jul 17, 2008 | 07:45 PM
jnmopar71's Avatar
jnmopar71
Thanks iI did have it at 17-18 but put it back at 15. Why does the over boost code come on when having it at 15 or even lower like 5psi?
Old Jul 17, 2008 | 07:48 PM
jnmopar71's Avatar
jnmopar71
so if you do have stage 1 for sale i would like to buy it.
