Engine Code
Old Jul 21, 2008 | 09:46 PM
lblackneon's Avatar
lblackneon
Default Engine Code
My car just started showing the code P0138-O2 SENSOR 1/2 VOLTAGE HIGH. It's never done that until recently. It has only been on a few times in the past week or two. Is that bad or is it nothing to worry about.
Old Jul 22, 2008 | 12:03 AM
AWH's Avatar
AWH
Default RE: Engine Code
Have you ever replaced your o2 sensor? It probably needs replacing.
Old Jul 22, 2008 | 01:31 PM
lblackneon's Avatar
lblackneon
Hmm. That's a possibility. With my Stage 2 pcm, it should bypass that sensor.
Old Jul 22, 2008 | 04:38 PM
PSI Chick's Avatar
PSI Chick
not if it's the upstream sensor that went bad. the staged ecu's only make the downstream sensor go stoich.
Old Jul 23, 2008 | 03:01 AM
AWH's Avatar
AWH
Yeah it's worth a try. They don't cost that much and it's easy enough to do yourself.
Old Jul 23, 2008 | 11:35 AM
lblackneon's Avatar
lblackneon
Okay. Thanks guys!
