Blue plate question...
Old Jul 30, 2008 | 10:11 PM
VTSRT4's Avatar
VTSRT4
Default Blue plate question...
After 1 hour of messing with the surge valve. I got the damn thing on. RR advice did help alot but I did one thing differently then everyone else. I disconnected the battery ofcourse. Detached the intake tube and took off the intercooler piping from the turbo so that i could have easy access to the 3rd bolt. I put everyone back together. Started up the car. It went pssssh....While driving I noticed something. When punching the gas. Is there suppose to be a loud hissing before it blows off???
Old Jul 30, 2008 | 10:50 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: Blue plate question...
shouldnt hear anything unusual before the blowoff. feeling different as far as power? boost levels changed? might be leaking now.
Old Aug 2, 2008 | 03:53 PM
VTSRT4's Avatar
VTSRT4
Well I tighted everything up. I still here the hissing. I didnt know if it was normal. Kinding has a nice sound with it but then Im thinking. The blow should be clean. I put RTV as a sealant. I thought I put enough on it.
I went to the track to confirm things. Kind of a sloppy way to find out if Im leaking. I did 4 runs. My first 3 runs were a 15.2 and my last run was a 15.0 flat. I dont WOT shift. I can shift quickly but that still seems slow to me. Reason behind that is because I had a 04 Celica GT that was turbo @ 6lbs of boost and my fastest run which was in the day ran a 15.0. With the celica stock with some bolt ons. I ran a 16.0.Im just thinking of taking the blue plate off and leaving it stock till I get a quality blow off valve. Not saying the mopar BOV is bad. Just not good to me. Im looking into the HKS Ssq package from modern performance. If I cant put on the blue plate right the first time. No reason to go messing with it to make it work. It spikes at 10 and goes down to 6-7. That aint right. Maype its the wrong sealant.
Anyone have any comments? Feel free.
EDIT: Wouldnt reinstalling it make the leak worse? Scrapping the sealant? Just to put it back on?
Old Aug 3, 2008 | 12:16 AM
flamingpinhead
Section Moderator
well, i would suggest doing a boostleak test on it... it is possible its not the bov causing the issue. coulda disrupted something in there messing around, a pipe/hose could have come off
Old Aug 13, 2008 | 10:40 AM
faststage02005's Avatar
faststage02005
driver mod...and some good tires and ur in the 13s
Old Aug 16, 2008 | 11:54 PM
LilSparkPlug's Avatar
LilSparkPlug
Are you sure you tightened the charge pipe on the back of the turbo up and that the coupler is completely around the turbo's outlet? That will make a hissing/whining sound under open throttle if not tightened properly. You have a serious boost leak somewhere.
