new parts....
Old Aug 5, 2008 | 11:35 PM
mr.lopez702's Avatar
mr.lopez702
Junior Member
Default new parts....
Hey guys I have some new parts for my car. I got the MSD DIS 2, New Plugs (iridium), and the MSD coil. I just wanted to know if i got to do any mods, or upgrades to the engine computer or anything at that before puttin this stuff in? Help me out plese.....* Thanks.
Old Aug 6, 2008 | 11:33 AM
PSI Chick's Avatar
PSI Chick
the msd coil pack is a good paper weight......not good for much else.
the dis-2 is ok...i had one for a while and ripped it out after getting stranded for 45 minutes in a dunkin donuts parking lot because it over heated and i couldn't start the car. you need a tach driver to use it, and the only feature that works is the 2-step. the wot box with built in 2 step is a better option imo.
irridium plugs are awesome, good choice. they work much better than coppers on our cars. smoother idle, smoother rpm range, just better over all. did you go with the denso or the ngk?
Old Aug 6, 2008 | 07:24 PM
mldsrt4's Avatar
mldsrt4
Default msd coil pack
.....i have always known msd to make some pretty good stuff.......i bought the msd wire and coilpack kit......havnt had any problems with it....obviously didnt notice anything improve.....but i would like to know.....what may be a better replacement for the msd coil......if there isnt much difference between any of them.....then i just assume keep it......its red so it matched my color scheme
Old Aug 7, 2008 | 02:26 PM
PSI Chick's Avatar
PSI Chick
stock is a better replacement than the msd. the aftermarket coils have a tendency to fail on our cars, just leave the stock one on there.
Old Aug 9, 2008 | 03:39 AM
mr.lopez702
Junior Member
Well i got NGK's. I was just waiting to put them in, untill i figured out if I wanted to put in that MSD pack that I got. But besides that tach adapter, I don't need that wot box? So I can throw it in after I get that adapter? thatnks i really appriciate this info. I'm new to building up my Neon, so any info. that i can look up and where would be great. Thanks.
JON
Old Aug 9, 2008 | 10:40 AM
PSI Chick's Avatar
PSI Chick
the wot box is a better unit than the msd. it has a two step built in and is designed to let you wot shift without damaging the transmission. in all honesty i would return the dis2 box and just get a wot box. it's cheaper and works better (i've had both)
