turbo upgrade.... what should i do.. help!!
Old Feb 24, 2005 | 10:54 PM
  #21
bellosiciliano18's Avatar
bellosiciliano18
Default RE: turbo upgrade.... what should i do.. help!!
so the psi-fi kit is better then the AGP kit??? i was actually thinkin about gettin the AGP kit this summer untill i read all this...seems like the psi-fi kit ives you everything you need to run a safe motor, correct??? and the AGP doesnt....???
Old Feb 25, 2005 | 03:11 AM
  #22
PSI Chick's Avatar
PSI Chick
well it's really a matter of which products you want to use. the agp allows you to chose your stuff, which can be good for those that have specific preferences, but bad for those that don't know what they want to use and don't know how to install and use them. the psi-fi kit comes with a new wga, mbc, and power paq which gives you all you need to control everything. you can tune it yourself or use a premade map that you can get from them. some people prefer to build their set ups and tinker with it themselves, then an agp set up would be better as it allows more flexability. for those that want a some what bolt on big turbo kit, the psi-fi is a better choice.
Old Feb 26, 2005 | 03:30 AM
  #23
bellosiciliano18
thanks for the info.... im gonna look more into the psi kif more when im ready for it... i was lookin for somethin like you said "blot on big turbo kit" lol sounds good to me haha
how much you think it woul cost with the kit and then plus labor....and where can you get somethin lik tht put in...cuz i wouldnt wanna mess with something like that my self...
Old Feb 26, 2005 | 05:48 AM
  #24
PSI Chick's Avatar
PSI Chick
the kit is about 3600 for the 57 trim, and i think it's 200 more for the 61. it can be put on at our shop in queens if you don't want to do it yourself. i honestly don't know the cost, but i can find out. we're doing a 57 trim in the next few weeks as it is, so i'll know exactly what it will run. mjv can pretty much do anything that you need, my b/f is a tech there and he works on all the srt's that come in, including mine. the shop is my sponsor, and he's pretty much the only one that works on my car there.
Old Feb 28, 2005 | 01:15 PM
  #25
NU2ltSRT-4's Avatar
NU2ltSRT-4
Haha about the 400 hundred I assumed that would be a rounded number that would put me close to where the basic turbo upgrade kit would be put me. If I'm wrong then so be it but that was my guestimate of HP for the basic turbo upgrade.
Currently I have a Apexi Boost Controller have on order the Borla Exhaust and as you recommended the Stage I.
But thanks for your help I'll give them a call at AGP.
I did have a goal of about 11 seconds for my car and thought that all of what I had put up might get me in that direction.
