100 psi oil guage and 150 psi oil press sender
Old Aug 22, 2008 | 05:44 PM
hub3rtSRT4's Avatar
hub3rtSRT4
Junior Member
Default 100 psi oil guage and 150 psi oil press sender
My friend gave me a 100psi cobalt autometer oil guage and I have a 150psi oil press sender. I was wondering if that would be accurate or not before I install it.
Old Aug 23, 2008 | 03:34 AM
SRT454SS's Avatar
SRT454SS
Member
i dont see why not.. a guage reads the pressure regardless
Old Aug 23, 2008 | 01:42 PM
LilSparkPlug's Avatar
LilSparkPlug
If you have more than that oil pressure you have an issue. It will read just fine . When you start it up the gauge should read around 100psi. Driving on the highway it should read between 30-50psi, and at idle mine reads around 20ish. You should be just fine. You can install it in the head of the engine. Underneath the intake there is a small plug with a square recess in it. Its a 1/8NPT just as the sender is....
Old Aug 24, 2008 | 01:26 AM
hub3rtSRT4's Avatar
hub3rtSRT4
Junior Member
ok.. thanks guys
