smoke comming from my exhaust
Old Aug 28, 2008 | 09:06 AM
mldsrt4's Avatar
mldsrt4
Default smoke comming from my exhaust
i just recently discovered my car smokes......but somthin dosnt seem i should say smell right......it only happens when i get on my car with high boost (17lbs) say 2nd and 3rd gear.....but it does not smoke when i accelerate...only on decceleration.....and its white smoke....but the smell is very strange....dosnt smell like gas, antifreeze or oil.....it smells like it does when there is a lit candle and you blow it out....any ideas
Old Aug 28, 2008 | 06:19 PM
1fast04neon's Avatar
1fast04neon
had very similar problem............ valve seals in my case
Old Aug 28, 2008 | 07:46 PM
GoBIGorGoHOME's Avatar
GoBIGorGoHOME
New Member
rings or valve seals.
Old Aug 28, 2008 | 10:36 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
$$$ in either case.....
Dusty
Old Aug 29, 2008 | 12:10 AM
1fast04neon
trust me LOTS of $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ b/c you CAN'T put a stock turbo back on and u cant use stock fuel and you have to buy cams i was like a kid in the candy store when i blew up lol ---- good luck ----
Old Aug 30, 2008 | 08:27 AM
mldsrt4's Avatar
mldsrt4
what do you mean i have to put cams in?........valve seals i can see, but why would it be so much money.....and also why would i not be able to put the stock turbo back on.....dosnt make sense i have stage 2 w/o toys that i just put on less then a month ago......any one have any suggestions on where i should buy parts i might need and what i might need.....ive only got 40k...and she runs rich.......and strong. and like i said originally it usually dosnt smoke....any help would be great
Old Aug 30, 2008 | 05:21 PM
1fast04neon
no no i was just kidding i was like a kid in a candy store when i blew my motor.....that was what i kept telling my self..... i dont want to leave it stock so while its all apart i decided to go all out... you can just have head redone and slap it back on
