Upgrading injectors!?
Old Sep 12, 2008 | 06:16 PM
diegom6's Avatar
diegom6
Default Upgrading injectors!?
Hello, I'm runing stock injectors from the SRT-4, I'm looking to upgrade these because they are bit small on the side by now and was looking for something btween 650-750cc, most likely 750cc.
I need 6 of em, I know these SIEMENS injectors are quite shorter than regular BOSCH or other brands in high impendance style. I was looking at ebay but I don't want to pick up the wrong fisic size so it won't fit in my fuel rail.
What are the next stages?
Thanks
-Diego
Old Sep 14, 2008 | 09:34 PM
PSI Chick's Avatar
PSI Chick
stage 2/3 are 682's. that's it from mopar. but there are modified stockers that you can get that run higher amounts. contact aaron from realtune. i'm running his 825's and they're great. same size as stock. i think his go as high as 1000cc's.
