ngk iridums
Old Sep 14, 2008 | 08:43 PM
mpain10's Avatar
mpain10
Default ngk iridums
is it best not to gap ngk iridums because i herd that they break easy
Old Sep 14, 2008 | 09:56 PM
LilSparkPlug's Avatar
LilSparkPlug
Any spark plug breaks easily if you don't know what you're doing. Gap them using proper technique and a spark plug gap tool and you won't have an issue. They come pre-gapped though.
Old Sep 14, 2008 | 10:55 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
should always check the gap on the plugs. just dont push against the little tip inside to widen the gap, that will cause it to break for sure.
