Stage 2
Old Feb 5, 2005 | 02:25 PM
bellosiciliano18's Avatar
bellosiciliano18
Default Stage 2
whats up everyone? i just recently put in stage 2 w/ turbo toys but i just had 1 question... where else can you hook up the intercooler sprayer besides your washer fluid...? because sometimes i use my washer fluid and if i hook up the intercooler sprayer from there and have distilled water instead of washer fluid then i wont be able to use it at all... was woundering what other people did, and also if you use a different bottle, what kinda bottle can i use so i dont have to use my washer fluid bottle....thanks, hope you get what im sayin haha let me know....
Old Feb 5, 2005 | 03:23 PM
PSI Chick's Avatar
PSI Chick
Default RE: Stage 2
i used a seperate tank to hook up the ic sprayer. i didn't want to be drilling into the washer resevoir, although in all honestly windshield washer fluid is just fine to be using on the ic. but anyway, here's a pic of the tank that i used. i got it from jc whittney, but some people have said that you can pick it up at pep boys (i've never seen it there, but give it a try).
Old Feb 5, 2005 | 06:39 PM
bellosiciliano18
Default RE: Stage 2
do you think you can send or post me a link to where you found that bottle on that site, that would be great, thanks alot for your help...!
Old Feb 5, 2005 | 08:08 PM
PSI Chick's Avatar
PSI Chick
Default RE: Stage 2
you know i can't find it anywhere. but someone did tell me that autozone has a overflow tank just like it for about $9, i believe he said it was for a motorcycle, but they're all the same anyway. try a local autoparts store and see if they have it, if not try the major online places like summit and whittney, one of them should carry it.
Old Feb 6, 2005 | 01:15 AM
bellosiciliano18
Default RE: Stage 2
o alright thanks for lookin anywayz... its just called a overflow tank...??? guess ill look around see if what i can find, thanks...
Old Feb 7, 2005 | 05:36 PM
bellosiciliano18
Default RE: Stage 2
hey i think i got the same one as yours... looks the same on the top... went to auto zone, asked for a "overflow tank" and he gave me 1...its says "vehicle coolant return system"...? and its 1 1/2 qt. do you have this same one??? and i didnt want to get the next size up ], which was almost douple so i just bought this one... hope it works....
Old Feb 8, 2005 | 04:30 PM
megaman's Avatar
megaman
Default RE: Stage 2
hey all you stage 2 owners how often do you need to refill your sprayer reservoirs when on auto mode-the car sprays itself?
