PERFORMANCE UPGRADE HELP!!!
Old Feb 12, 2005 | 05:51 PM
HEMISRT's Avatar
HEMISRT
Default PERFORMANCE UPGRADE HELP!!!
hi i was going to change turbo but im on tight budget
so... beside change turbo, what can i do?
i want to get maximum power from stock turbo
you guys please list all parts
Old Feb 12, 2005 | 08:07 PM
PSI Chick's Avatar
PSI Chick
Default RE: PERFORMANCE UPGRADE HELP!!!
well you have two main options. one is the mopar stages, the other aftermarket parts. it all depends on how much you want to spend and how much tuneing you want to do.
stage 2 will put you around 260-280hp, run 12's with dr's at the track. it's bolt on, no tuneing needed. you have the option to get toys which are pretty nice.
if you go aftermarket, you should get s1 anyway. but then there's the wga and mbc route.
of course supporting mods for each path should be considered, such as exhaust, fmic, throttle body, motor mounts, and the like.
there's a never ending debate about mopar vs. aftermarket. each has it's pluses and minuses, but it's more about what you want for the car.
