What is the difference?
Old Jan 30, 2009 | 04:06 AM
night709's Avatar
night709
Default What is the difference?
I was looking into getting an SRT-4 and wanted to know the difference in the 04 and the 05. Wanted to know about the power difference between the two are and if the 04 had the LSD in it or not and so fourth. Thanks for any help you can give.
Old Jan 30, 2009 | 07:51 AM
PSI Chick's Avatar
PSI Chick
there is no difference
Old Jan 31, 2009 | 02:26 PM
mxrnick's Avatar
mxrnick
psi said it all
Old Feb 11, 2009 | 01:51 PM
LilSparkPlug's Avatar
LilSparkPlug
04s came with LSD. The differences between the two are nothing that would ever effect the way that you do things. The PCM had different programming, but that was a DCX thing at the time. Your cluster lights are soldered and don't have sockets like the 03/04s do. If you buy an 04, make sure its an 04 BUILT in 04, since the 04s built in 03 still have 03 axles which are weaker. 05s have a common third gear synchronizer issue as well.
05s also had ACRs and Commemorative editions as well.
Old Feb 11, 2009 | 04:56 PM
PSI Chick's Avatar
PSI Chick
most 03 axles were broken by 04 haha
Old Feb 14, 2009 | 08:47 PM
Pressurecooker's Avatar
Pressurecooker
Damn, after all this time when I can get around to coming on here, I still learn something new from the girls....Ha ha. Good job!
This is why I still check in.
