Blow-off valve
Old Feb 27, 2005 | 04:03 AM
pissstain's Avatar
pissstain
Default Blow-off valve
looking to go with a greddy type-s blow off valve, has anyone already done this? it should be pretty much plug and play... if not what else needs to be done?..
Old Feb 27, 2005 | 06:31 AM
PSI Chick's Avatar
PSI Chick
Default RE: Blow-off valve
you need a block off plate and at least an upper pressure pipe with a flange welded on. the bov should come with all the fittings and hoses needed to install it.
Old Feb 27, 2005 | 07:31 PM
OrochiDio1's Avatar
OrochiDio1
i wouldnt recomend a greddy BOV my friends sr20det went thru 3 of them and my rx-7 blew a type-s up.. i recomend HKS SS ive never broke 1 and never seen anyone else break one..it seams the diahfram on the greddy is weak.
