Boost problem
Old Feb 28, 2009 | 08:27 PM
roo69er's Avatar
roo69er
Default Boost problem
I made took 45 minute freeway drive today and when I arrived the exit ramp i got about a mile in and then the boost started going out on me in all gears. I can step on the gas to the floor and once the boost gauge starts to go above 0 it cuts the gas and i get no power... I checked to see if it was throwing a code... and nothin. i start it up again and its fine. So i drive home... same distance and about a mile off the freeway same thing happens. I have an idea of what it could be... but i wanted to see what you all might think. any idea?
Old Mar 1, 2009 | 02:38 AM
mxrnick's Avatar
mxrnick
i dunno sounds electrical maby
Old Apr 29, 2009 | 08:04 PM
roo69er's Avatar
roo69er
Default Bad Fuel pump
so it ended up being a bad fuel pump. not enough A/F and the comp kills the gas when u start getting into boost, and bogs out. The Fuel pump (which is around the passanger side rear tire, inside the tank) started humming quite loudly ( like a Chevy suburban) luckily my extended warranty covered it the OE part is like 424$ add on labor...
