??fuel cut??bad fuel??plez help.s2 lotta work done stock turbo
Old Apr 4, 2009 | 02:01 PM
charlessrt33's Avatar
charlessrt33
Default ??fuel cut??bad fuel??plez help.s2 lotta work done stock turbo
iv done alotta work to my car and have put about 3thou miles on it since the bc cams and springs were done and now only under like 8-15 psi it goes bddd lol like a harley or something (i can get it at a constant) only under boost i have full rpm range new plugs and wires(not coil msd) total 45 thou miles on the car no codes....took for many rides with a drb3 used to work at a dodge dealer ship and am having a service man help me with it but we are kinda at a dead end do the fuel pumps go bad under a load? or what goes bad under a load? boost gauge, and me over boosting? cuz when i put it back togher i had to crank down the boost cuz i blew all the lines and with this problem down shifting i dont get the CRACK that the full 3 in used to do *used to do the same thing when i had meth hooked up and it would drip...no meth for now tho* lotta work done plez ask and tell all thanks (this started when the tanks went on E and i filled it thinking i was outta gas... guess not)
Attached Thumbnails ??fuel cut??bad fuel??plez help.s2 lotta work done stock turbo-srt-4.jpg
Old Apr 4, 2009 | 04:00 PM
_zer0's Avatar
_zer0
what are your spark plugs gapped at? usally its not fuel cut your hitting but spark cut...try gapping them to .040 and see if it changes, and go lower if ur running more boost if the spark gap fixes it. did u ever have your tps wiring replaced? check that too cuz it goes out real easy on our cars
Old Apr 4, 2009 | 06:40 PM
en00be's Avatar
en00be
your blowin spark buddy, get some new plugs and gap them.
this should fix your problem.
what injectors are you running?
What are you using to tune it?
Old Apr 5, 2009 | 12:56 AM
charlessrt33
il try it i supose but with the 23000 miles iv put on its iv flip plugs in and out of it cuz of working at the shop...never gaped them... then y all of the sudden now? i got a agp waste gate and iv tuned it wayyy down and im blowing spark at 8-12 psi?
Can you over spool a stock turbo on a built motor?
Old Apr 6, 2009 | 02:33 PM
en00be's Avatar
en00be
Default Yeah
it all depends how many pounds its went to.
What's the most boost you'v gotten outta it?
You can blow spark on 5 psi dude....get yer plugs gapd
Old Apr 6, 2009 | 09:18 PM
charlessrt33
ya iv boosted 15-18 on a reg. with the same plugs... just kinda happened in the middle of a ride like less than a miles from the shop and ya i ripped outta the shop and it was running good
Old Apr 8, 2009 | 07:20 PM
mldsrt4's Avatar
mldsrt4
sound like a quick fix thats to cheap and easy to work lol?......its like on southpark the cure for cancer is $100000 cash injected right into your blood stream.....cash cures all
Old Apr 9, 2009 | 12:40 PM
charlessrt33
Ended up being the fuel...put some in a jar and let it sit and theres all kindas of crap in the bottom... i dont know if someone put it there or if something elese happened to get water in the system but now i got almost a full tank to flush and fill *plugs gaped*
