What do i need to use this BOV
Old Mar 8, 2005 | 04:22 AM
2005 SrT4 2005's Avatar
2005 SrT4 2005
Default What do i need to use this BOV
The Bov im wanting to get is the Turbo xs rfl bov. What do I need to make it work and is it hard to install yourself. I will list the items i think i would need. I have been doing alot of searching on it and i just want some input on this.
some type of intake so the bov will make a louder sound
Turbo xs bolt flange for bov thats i think around $80 to $100
Turbo xs rfl bov I like the loudness of it $170 to $200
Is that all i need or do i need a hardpipe. What exactly is a Hardpipe is there one on on each side of the intercooler or just one im not sure.
Is this something I can install myself or if I cant is it expensive for someone else to do it. Around here there probly like me and never messed with a turbo based car
Old Mar 8, 2005 | 10:14 AM
Narcisse91's Avatar
Narcisse91
Default RE: What do i need to use this BOV
First, with a BOV that loud, you don't need to worry about replacing the intake to make it louder. The stock surge valve is pretty loud with an intake.
Hardpipes replace the plastic intercooler tube. Since you can't put an aftermarket valve in the factory location (except for the Forge), you need a place to mount it.
You'll also need to remove the factory surge valve and install a block-off plate.
The install isn't difficult, but if you've never done anything with turbocharged cars, you may want to have someone else do it, as you'll need to screw around with vaccuum lines, as well as work in some pretty tight places.
Old Mar 9, 2005 | 02:53 AM
OrochiDio1's Avatar
OrochiDio1
and that damn 3rd bolt ARGH!
Old Mar 14, 2005 | 07:43 PM
black4's Avatar
black4
i here ya on that 3rd bolt it was a major paine in the ****.
