engine coolant
Old Mar 10, 2005 | 10:02 AM
johnyspeedo's Avatar
johnyspeedo
Default engine coolant
I was wondering if i could use coolant that is already mixed into my engine coolant tank...you know the kind of coolant that comes pre-mixed
thnx
Old Mar 10, 2005 | 01:46 PM
doof432's Avatar
doof432
Default RE: engine coolant
you could, but i have not ever seen any that is the orange kind premix... You probably know, but you cannot use the green anti-freeze. You must use the more expensive orange stuff that last alot longer. As long as you use the orange suff, then you are fine, premix or not...
Old Mar 10, 2005 | 03:18 PM
PSI Chick's Avatar
PSI Chick
peak coolant with the orange top. you can get it at any auto parts store.
Old Mar 10, 2005 | 06:03 PM
srt4 driver's Avatar
srt4 driver
Or that yellow stuff that works with Orange and Green Cool Juice.
Old Mar 11, 2005 | 03:00 AM
casper's Avatar
casper
Prestone makes a mix that is good for all cars.
Old Mar 14, 2005 | 02:07 AM
200srt4's Avatar
200srt4
so what coolant is recommended to use in the SRT-4? if i understand correctly, not the green one...?
Old Mar 14, 2005 | 03:22 AM
casper's Avatar
casper
No, I forget the name of it, but its the orange one. As I already mentioned, the Prestone is good for all types of cars.
