stage 2 ???
Old Mar 16, 2005 | 07:40 PM
black4's Avatar
black4
Default RE: stage 2 ???
there is a stage 1 kit but its ecu and injectors only. to answer your other ? i believe the stock sensors say 2 bar i believe don't " " me on that.
Old Mar 16, 2005 | 07:44 PM
boosted19's Avatar
boosted19
do the stage one say stage one on the ecu?and only have a 2 bar sensor..sorry for all these annoying ??
Old Mar 16, 2005 | 07:47 PM
black4's Avatar
black4
yes and yes.
Old Mar 16, 2005 | 07:52 PM
boosted19's Avatar
boosted19
cool..i really appreciate it man..
Old Mar 16, 2005 | 07:56 PM
black4's Avatar
black4
any time to eliminate your friends bs.[sm=burnout.gif][sm=bs.gif]
Old Mar 16, 2005 | 10:03 PM
PSI Chick's Avatar
PSI Chick
fyi - some of the early stage 2 ecu's had the stage 1 stickers on them, so that's not always the best way to tell. the tell tale sign is the map sensor, it will say 3 bar. you cannot run a stage 2 ecu without the sensors.
all srt's have a sensor on the intake.
Old Mar 17, 2005 | 11:06 AM
boosted19's Avatar
boosted19
ok i looked at the sensor on the intake manifold.. it said 3993 i belive... anyone have pictures? i might be looking at the wrong sensor... on the ecu i couldnt really read it. but it said software upgrade......
Old Mar 17, 2005 | 12:03 PM
boosted19's Avatar
boosted19
i dont know if i was looking at the right sensor...it looks to be the only sensor on the intake manifold.. i does not say bar anywere on it??hmm im confused...were would it say bar on it? thanks matt
Old Mar 17, 2005 | 03:46 PM
PSI Chick's Avatar
PSI Chick
see that sensor sitting right in the front below the injector cover? that's the map sensor. look at it. it will say 3 bar on it if s2 is in the car. it won't if s2 isn't there.
Old Mar 17, 2005 | 03:52 PM
boosted19's Avatar
boosted19
hmm it didnt have anything on it but some 3993 number.. and a white out mark! guess its not s S2.. f'n liar...
