3rd gear boost spike
SO i just bought my srt about three weeks ago .
just recently took it to the strip and noticed first and second gear hold boost at 17 just fine , shift to third and the boost spikes over 20 pounds, im guessing wastegate ???
Still a problem i just take it easy now... No hard core gasin it atm.
The car is completly stock besides the mopar blow off as far as i know.
And it has a CAI
And an APG wastegate
And when i take the pin out of the WG it feels broke or lose like i can move it allll around.. Is that normal??
But i have still not fixed this problem.
And it has a CAI
i usually run about 19 lbs but the other day i clicked third n it spiked 26 lbs n blew two hoses off wastegate? i put a boost controller on and it helped of course but it still tries n hits 19 sometimes n i turned it down to 16
its the gearing of the transmission that makes a higher spike in different gears.
There is a locking nut on the AGP that needs to be tightened or else it will adjust itself. A boost controller or bleeder can be used to regulate the spike like you did, but optimum psi range for stock turbo is about 18-19.
