help!! car only gets boost if i floor it
Old Sep 24, 2009 | 05:35 PM
spoolinsrtneon's Avatar
spoolinsrtneon
Default help!! car only gets boost if i floor it
my car will never go past 3 or 4 pounds of boost unless i floor the peddle fast mutiple shops have checked it with no result wastegate is new all sensors are new i gata figure thi9s out!!!!!
Old Sep 24, 2009 | 05:47 PM
70x7's Avatar
70x7
a shop wont check for boost leaks. Chances are you have a loose clamp or open hose all together
Old Sep 24, 2009 | 05:49 PM
spoolinsrtneon
i had them run vacuum and boost leak check and it came up fine
Old Sep 27, 2009 | 12:11 AM
Moparmatt440's Avatar
Moparmatt440
it has to be some thing loose, its a big boost leak. For a boost leak you need positive pressure and a spray bottle with soapy water. I would still go through and retighten all your hose clamp and zip tie any vaccum hoses.
