a stage 2 question
Old Dec 1, 2009 | 03:03 AM
808srt's Avatar
808srt
Default a stage 2 question
i have a quick question i have a guy here selling his stage 2 computer and i was woundering if you needed the 3bar map/tip sensor in order for it to work cause i already have 750cc injectors and a agp wga cause i already have everything else for my car (3''intake, 3''turbo back, 3'' o2, 62mm tb, WAG, Exhaust Depot superbeast fmic, mbc, plugs, wires, walbro 255, 750cc injectors) so i figure that would be a good addition to the car until i can save enough money for the big turbo agp 50 trim. or should i not get the stage 2 and just save for big turbo
Old Dec 1, 2009 | 03:08 PM
mxrnick's Avatar
mxrnick
save for a big turbo those injectors are way overkill for a stock turbo. with a big turbo and a dsp you will be all set and not need any stage computer cause the dsp will tune the stock one
Old Dec 1, 2009 | 03:09 PM
70x7's Avatar
70x7
depends on the price. I had the S2 ECU on my big turbo and I liked it, if anything, I did it for the extra rpms. But yes, I did have the S2 MAP and TIP sensors also.
