any clue?
Old Apr 22, 2005 | 09:54 PM
seanardy's Avatar
seanardy
Default any clue?
i have a bone stock 05 srt4 and i only have 3k on it so far anyways i noticed on my boost gauge this days that everytime im on park my boost gauge sits at 19vac and before it was atleast 19 1/2 or sometimes 20 vac and i dont know if its normal but when the engine shuts it sits at 0 and also what is the max psi the stock can reach?i noticed on my car too is before when i redline it my car seem went slow and the psi drop alittle.any ideas guys?
Old Apr 23, 2005 | 02:03 AM
Gump's Avatar
Gump
Default RE: any clue?
when your engine is off you arent producing any vac or boost so your gauge goes to 0.
highest psi stock i got was 15.
and your psi will drop at redline for a stock car.
Old Apr 23, 2005 | 04:40 AM
posthondaremoval's Avatar
posthondaremoval
Sounds pretty normal. Keep in mind that these cars make a good bit more torque at 4000rpm than they do at 6000 rpm. If you look at dyno charts, you will always see a drop off in power before redline. When dragracing, often people shift before redline to keep it in the torque band.
Old Apr 23, 2005 | 12:04 PM
roachnigga's Avatar
roachnigga
its normal
Old Apr 23, 2005 | 01:27 PM
seanardy's Avatar
seanardy
oh ok...thanks guys
Old Apr 24, 2005 | 04:56 AM
Gump's Avatar
Gump
ORIGINAL: posthondaremoval
You get higher trap speeds if you hold till red line.
Old Apr 24, 2005 | 10:34 AM
posthondaremoval
ORIGINAL: Gump
I didn't say I short shifted.
I have played with it, though, and in second gear it "feels" like it pulls harder on the 2-3 shift with no lag when you do. Also you get no wheelspin. But who knows, really, at the dragstrip, I am more of a street warrior and handling guy most of the time.
