a huge prob. i need help!!!!
Old Feb 8, 2010 | 01:11 AM
808srt's Avatar
808srt
Exclamation a huge prob. i need help!!!!
i have a very big problem it all started at the track and keep in mind ive been down the 1/4 mile about 100 times just meaning this wasnt my first time but anyway i went down the track all went well like usually but on my way back around the track my brake didnt work. it was impossible to push down and would only go down about 1/2 an inch and i dont know whats wrong and the car is now reving very high at like 2000rpms and is stuck there for like 10 seconds then it goes down to around 1500 rpms witch is still high and on top of that you can here a flutter in the intake like when you slow down but it doesnt stop making the noise thanks for any and all help
Old Feb 8, 2010 | 07:48 PM
mxrnick's Avatar
mxrnick
its the brake booster vac line. if you look right behind the battery there is a big black round drum called the brake booster and it has a vacum line running from it to the bottom of the intake manifold in between the second and third runner. its kinda hard to get to so when you get it back on make sure you ziptie it so it wont pop of again. hope this helps
Old Feb 9, 2010 | 10:57 AM
70x7's Avatar
70x7
^yep.
Secure that line with like said above, a zip tie, or I did mine with an actual hose clamp.
Fortunatley, yours popped off at the track and not like mine did on a downhill road!
Old Feb 9, 2010 | 02:48 PM
mxrnick's Avatar
mxrnick
^ yea i agree i use hose clamps too mainly cause i dont like the look of all the zip ties. and the hose clamp is reusable for when you need to work on stuff. i just suggest zip ties first cause most everyone has some.
Old Feb 24, 2010 | 05:51 PM
808srt's Avatar
808srt
Thank for the help that is what the problem was
