greddy type rs install.
Old May 1, 2005 | 03:30 AM
Gump's Avatar
Gump
Default greddy type rs install.
okay so i have the type rs bov installed with the bov in place and pink line running to the bov... but i heard that you should use the throttle body line? and block off the pink line?
If this is true can so one eather tell me in detail or show pics of the lines to use and how would i block off the pink line?
Old May 1, 2005 | 03:26 PM
PSI Chick's Avatar
PSI Chick
Default RE: greddy type rs install.
rip out the pink line from the car, yes i mean that. cap it at the solinoid by the battery. you can use any type of cap, doesn't matter as long as it fits properly. t into the line that comes off the tb. there's one major vacuum source that comes from the tb, it's a big black line, you can't really miss it. leave a good 6" or so from the nipple and cut the line. put in the supplied t bracket there to connect the hose back together, and then run a line from the t to the bov. don't forget to zip tie everything so that nothing blows off. that's it!
oh, and don't forget to use copper atv on the bop so it doesn't leak!
